NAA vane pump follow-up
Ron K 2N/NAA
09-23-2001 04:59:04
My vane pump was starting to go, and I searched the archives for any info. I couldn't decide whether to rebuild vane pump or put on piston pump. A dealer quoted me prices of $795 and $2000, respectively. When searching the archives, I happened across a thread which mentioned replacing the vane pump with a gear pump. I contacted llamas, who posted the thread. He put me in touch with John "The Old Tractor Guy" out in Colorado. I bought a rebuilt gear pump and manifold from him for $300 plus shipping, and it works just great. Bolts on right where the old vane pump comes off-no sweat. So, for those who have this problem in the future, I would recommend this fix. It saved big bucks and works like a champ. John "the Old Tractor Guy". can be contacted at jjbow@worldnet.att.net. Thanks to both he and llamas for the help, and thanks to this board for the contact.
Dman
09-23-2001 18:11:12
 Re: NAA vane pump follow-up in reply to Ron K 2N/NAA, 09-23-2001 04:59:04
Ron: I just purchased the same set up for my NAA
when my vane pump crapped out, did you do anything
special to prime the pump, I cant' get mine to work. Thanks for your help in advance.
Ron K 2N/NAA
09-24-2001 06:47:13
 Re: Re: NAA vane pump follow-up in reply to Dman, 09-23-2001 18:11:12
I'm no expert, but was thinking some more about your problem. If the air fix didn't work, you may have the wrong o-rings. If it's sucking air, it won't prime for you either. I went right to NH and got the o-rings. Where the manifold connects to the pump, they are flat "washer-type" O-rings. Where the manifold connects to the sump, they are "rounded" O-rings. This worked for me. Hope it helps-let me know.
Ron
Ron K 2N/NAA
09-24-2001 06:04:07
Go to the small hole where the hydraulic dipstick goes in. Take your air compressor and put a little (maybe 5 to 10 lbs) of air into the hole and the hydraulics should come right up. Mine chattered for a day or so, til the air went out of the lines, but it works perfect now. Hope this helps. Let me know.
Ron
