Rear wheel wobble
Paul
09-23-2001 18:38:09
Both rear wheels on my 8n wobble. There is enough play in them that I can push the top of wheel and it is like a loose wheel bearing. Is there something I can do to fix it? I have tried tightening the axle nuts but they are still loose.Anybody have any ideas?
Thanks, Paul
Gary
09-24-2001 03:10:35
 Re: Rear wheel wobble in reply to Paul, 09-23-2001 18:38:09
Have you tighten them to 450 lbs. thats what they need to be. If so you may be looking at new axles and hubs as well as bearings. does it leak fluid out the seals? good luck
Gary
09-24-2001 03:10:27
Gary
09-24-2001 03:10:19
bg
09-23-2001 20:42:33
New bearings.
Paul
09-23-2001 20:58:12
 Re: Re: Rear wheel wobble in reply to bg, 09-23-2001 20:42:33
Thank-you for the advice. I was afraid of that.Got wheel wieghts and all that stuff on it. Good time to replace the tires while I'm at it, brakes too.
