9N
rear brake lever - how to remove slop from shaft?
Randy Messer
09-27-2001 19:55:52
My Dad's 9N has a lot of slop in the left rear brake pedal, and the clutch lever will occasionally 'hang up' on the left rear brake pedal, which swings over and interferes with the travel of the clutch.
What's the best way to eliminate the play on the brake lever - replace, rebush, other?
Thanks!
Dave Todd
09-28-2001 09:30:07
 Re: 9N - rear brake lever - how to remove slop from shaft? in reply to Randy Messer, 09-27-2001 19:55:52
Randy, I think I would try putting a bushing in the arm. But, there might be some wear on the shaft itself, which would require build up and machining.
Good luck!!!
Dave
