Order Ford 8N Parts Online
How do you remove lift shaft on an 8n
Andy
09-28-2001 21:03:26
I am trying to remove the lift shaft from my 48 8n. I have the lift cover apart, the lift arms off and now the manual tells me to remove the lift shaft. The problem seems to be that the splines in the center of the shaft,for the ram arm appear to be hitting the lift shaft bushings. Is this somthing I have to press out? thanks, Andy.
Martin D.
09-28-2001 22:18:13
 Re: how do you remove lift shaft on an 8n in reply to Andy, 09-28-2001 21:03:26
Mine required a 30 ton press and an incredible amount of heat from a huge torch tip to come out of the arm that the hydraulic piston pushes against. And it also pushed out one of the bushings as well with the central spline.
