Order Ford 8N Parts Online
Rewiring 12 volt 8N---Terminal Block Question
Old8Ner
09-29-2001 21:17:34
I am in the process of rewiring my already converted 12 volt 8N,and need to know which two terminals to use on the original 3 prong terminal block.This block has two terminals on bottom with a coiled type wire running between them,and one terminal on top isolated from the other two. Does it matter which ones to use? Any help greatly appreciated. Thanks!!!
Gary
09-29-2001 22:03:46
 Re: Rewiring 12 volt 8N---Terminal Block Question in reply to Old8Ner, 09-29-2001 21:17:34
The single terminal is where the 12 volts from the ignition switch comes to all other switched circuits can get there 12 volts from this point. The 2 terminals with the coiled wire {resistor} is your coil circuit. Hope this helps
