PTO will not stay engaged
Red Dog
10-01-2001 19:04:56
The PTO will not stay engaged on my 8n tractor. Is the PTO shaft supposed to slide in and out with the lever ???
Claus
10-02-2001 07:20:53
 Re: PTO will not stay engaged in reply to Red Dog, 10-01-2001 19:04:56
No, the shaft does not slide. There is a coupling that engages the pto shaft to the counter transmission shaft. Your problem is relatively a common problem. Things to look at are the shift rail, shift rail stop, detent ball, interlock spring, condition of the pto shaft splines, and play in the PTO Shaft...
Happy Motoring
Claus
Dave (MI)
10-01-2001 19:54:32
I was just thinking. Is the PTO lever popping out as you release the clutch?
If so, try holding the lever back as you release the clutch. Not forcing, but enough pressure to help it engage. If this is the problem you might have a internal problem.
Dave
8N
Dave (MI)
10-01-2001 19:51:38
Which shaft are you talking about?
The lever on the tractor should engage to PTO and the 3pt hydralics.
I don't think the shaft coming out of the tractor should move in and out at all.
The shaft on the equipment you are attaching should have a button to lock and unlock it from the tractor shaft.
Hope that helps, maybe a little more detail!?!
Dave
8N
