Steering wheel repair
Rick(Ont)
10-03-2001 11:24:22
I have seen posts here over the last year or so regarding repairing steering wheels. I just wondered if anyone has tried to fix one up using Bondo, and if so, had any success?
Thanks, Rick
MATT
10-06-2001 20:34:47
 Re: Steering wheel repair in reply to Rick(Ont), 10-03-2001 11:24:22
I've repaired several steering wheels with cracked or chipped covering. The best product I've come to use is plumbers two part (epoxy)puddy which comes in a cigar shape tube, it may come in other forms too. It's like plasterseen puddy gray outside with white inside core. You break off a piece and nettle the two parts in you hand until well mixed and soft, then place and mold it onto the steering part to repair. It hardens within about 5 mins. after which you can file and sand, and then paint.
It's far better then Bondo and no mess. Also it can be use for other repair work. Believe me, it worked great on my steering wheels, almost can't tell the difference from the original material.
Jim
10-07-2001 08:47:58
 Re: Re: Steering wheel repair in reply to MATT, 10-06-2001 20:34:47
What kind of paint did you use on the steering wheel?
Rick(ont)
10-05-2001 10:58:08
Thanks for the suggestions, guys. I'll let you know how I make out.
Rick
Stuart K ( also in Ont )
10-04-2001 07:56:32
Hey Rick where on Ontario are you? I'm near Fergus. I'm looking for a good way to coat my wheel, It's in good shape but needs sealing anyone have any suggestions. Thanks. StuK
Rick(Ont)
10-05-2001 10:57:01
 Re: Re: Steering wheel repair in reply to Stuart K ( also in Ont ), 10-04-2001 07:56:32
Hey Stu, I'm not too far from you, I'm in Milton. I Know where I can get new replacement steering wheels for about 70 bucks, but I want to keep mine. Also I don't know if you know of him, but Don Watson is very close to you and he has a whole boneyard full of Ford N stuff.
Rick
Jim
10-04-2001 06:18:47
Yes I used bondo and filed it down with sand paper and I think it is ok.
goodluck Jim in AZ.
Ed Gooding (VA)
10-03-2001 15:50:54
Hi again, Rick. Eastwood Co. sells a steering wheel restoration kit, with instructions. You can check it out by clicking here. Enter 52054 in the Search by keyword box, and it should take you right to it.
Hope this helps..... ..... .Ed
'52 8N475798
Richard(WY)
10-03-2001 12:32:16
Rick, I used plastic metal in thin layers building it up. then filed and sanded to shape. Then I rubber coated it with the stuff that you dip plier handles into. It has lasted about 5 years now and still looks good and doesnt leave your hands stained black.
