Dont let this happen to you
9Njoe
10-03-2001 12:16:02
I am currently rebuilding the top end of my 9N. I was installing the new valve train and one of the valve rotator cups fell off and went right down the oil gally and into the crankcase.
So I guess that I will be removing the oil pan tonight to retrieve the sucker (and the magnet I lost in there trying to get it out) Ha. Guess I am gonna do the crank seals while I am in there. Lesson number one, stuff a rag into the oil holes when you are doing valve work.
I hate it when I do that :-o
Joe
swavo
10-03-2001 18:19:12
 Re: Dont let this happen to you in reply to 9Njoe, 10-03-2001 12:16:02
Been there , done that! where were you last year when I replaced a valve and had the same thing happen to me?
Dave Smith, Well
10-03-2001 14:17:20
As long as you have the pan off might as well rebuild the oil pump and check the bearings. How was the compression. After a while you do run out of things to check in there. Been there done that. Poorer because of it.
Dave <*)))><
bg
10-03-2001 16:37:34
 Re: Re: Dont let this happen to you in reply to Dave Smith, Well, 10-03-2001 14:17:20
Yes, but richer for the experience....
bg
10-03-2001 12:41:26
Isn't it one of Murphy's Laws that nothing is as easy at it looks? I think it may be the Law of Cumulative Propensities, where one thing leads to another.
