Tightening clamp on 51 side mount distributor
Rad
10-03-2001 19:25:46
Does anyone know who might still sell the clamping bracket that holds the 51N side mount distibutor in place after the timing is set? I have tried Ford-New Holland but they tell me it is no longer available. I checked with "Just 8N" and they do not sell them. HELP!!!
burk
10-04-2001 09:45:33
 Re: Tightening clamp on 51 side mount distributor in reply to Rad, 10-03-2001 19:25:46
Is your clamp missing or damaged beyond repair?
If so, you might try a tractor junkyard. I found an index of junkyards around the country at the link below.
If your clamp doesn't hold when tightened all the way, you can probably fix it. I had the same prob on my '52 8n. Pull the distributor and remove the clamp. I had to do a little straightening in a vice. Once you have it in your hand you will see what I mean. I got the advise on this board back in January or February. Works great now. Good Luck. If the link doesn't show I'll also post it here:>Link
