Bent PTO shaft... after hydraulic pump
Red Dog
10-03-2001 20:23:22
I have a bent/twisted PTO shaft. The shaft has twisted splines after it goes through the hydraulic pump. The splines are twisted enough that I can't pull the shaft through the pump cam in the hydraulic pump. Do I just have to cut it off and pull it out or is there another way.
Thanks
Red Dog
Dell (WA)
10-05-2001 12:42:17
 Re: Bent PTO shaft... after hydraulic pump in reply to Red Dog, 10-03-2001 20:23:22
Red Dog..... .yep, gonna hafta cut yer PTO shaft. Been reported that a "Saws-all" do it much better than a cutting torch. Flames and oil not a good combo.
Next time, use an Over Running Coupler (ORC) on your PTO shaft when brushoggin', $60 cheep..... ..Dell
