Order Ford 8N Parts Online
8n 6v coil
Rick Stewart
10-04-2001 01:05:24
pos or neg to distributor?
Claus
10-04-2001 04:27:06
 Re: 8n 6v coil in reply to Rick Stewart, 10-04-2001 01:05:24
Assuming you still have a pos ground, then pos to the distributor.
Happy motoring
Claus
Are you sure , Claus ?
10-04-2001 19:21:12
 Re: Re: 8n 6v coil in reply to Claus, 10-04-2001 04:27:06
yes . . . Dell (WA)
10-04-2001 22:00:40
 Re: Re: Re: 8n 6v coil in reply to Are you sure , Claus ?, 10-04-2001 19:21:12
points are "ground", therefore if battery positive is ground, then coil positive goes to the points which are ground. Applys for a sidemount 6 volt distributor/coil system.
Front mount ignition coil has no polarity option, it is internally wired for positive ground..... .Dell
