Order Ford 8N Parts Online
1947 8N engine rebuild
paul n.
10-05-2001 15:59:58
The engine that I am working on ran last year,but the winter took its toll.There was one valve in each cylinder that was stuck open,so I removed the head and was able to work two of the valves loose,but there was still two others that were stuck.the engine is off the tractor and the oilpan is removed.now i need to remove the camshaft in order to drift out the two stuck valves out. How do I get the camshaft out,anyone?
bg
10-07-2001 06:30:48
 Re: 1947 8N engine rebuild in reply to paul n., 10-05-2001 15:59:58
You'll have to get the valves and tappets off the cam lobes before you can pull the cam. Take the side covers off and soak the stems with Blaster or diesel fuel or some kind of penetrating oil to see if you can free them up. You might then be able to turn the cam and wiggle it out.
