Ryan, 3 bottoms is a lot to ask of an 8N. I suppose it can do it if the soil is loose enough. But if you are turning sod, then I wouldn't count on it. Plows are three dimensional. There is pitch, roll and yaw (or angle of attack), just like with airplanes. The pitch of the plow (nose to tail) will determine depth. If the nose of the plow is not pointed low enough, it will glide along the top. Adjust the pitch with the top link. The 8N book says the top link should be 25". Also, the rear wheel on some plows can be adjusted to control depth. The roll (left to right) must be parallel to the ground so that all moldboards are cutting evenly. Adjust this with the right leveling arm. The yaw, the angle of the plow line of sight relative to the line of sight of the tractor, determines the width of the cut. Most plows allow you to adjust this by loosening a couple of bolts near the 3 pt. connection and then rotating the lower link mount points on the plow. This is why the mount points have bends in mount points... to adjust the cutting width. All of these must be adjusted to get a good turn on soil. And the last element is speed. If you are moving too slow, the plow cannot throw the soil with enough force to flip it over. Also, make sure the lift is all the way down. It should be in "draft" mode. The small lever under the right side of the seat should be lower to be parallel with the ground. Try getting a 'plow' book. Many suppliers of books on the principals of plowing, The 8N owner's manual also covers this. Also read up on draft control versus position control on the 8N. Hope this helps! Patrick www.n-tiques.com
