Lift Control
R.M. In Al.
10-06-2001 19:38:38
Im having trouble keeping my lift leaver up.It drops when I am not expecting it .The lift works fine but I have to hold up the leaver to keep the lift up.What is the probable reason for this Im sure some of you fellas have had this problem also. Thanks everyone..R.M. in Al.
ZANE
10-07-2001 05:46:38
 Re: Lift Control in reply to R.M. In Al., 10-06-2001 19:38:38
Dale is right!
Be sure to not overtighten it because it will tighten but it won't un tighten. The aluminum disc part will allways be grown to the shaft and it will usually move inwards but not out. It takes heat and strong words to get it to come back off! The friction clutch disc can be fabricated from thick gasket material if you are not close to a dealer. If any of the original friction disc is still in place don't even try to replace it. You'll be sorry!
R.M. In AL.
10-07-2001 19:07:44
 Re: Re: Lift Control in reply to ZANE, 10-07-2001 05:46:38
Thanks Zane and Dell. I do not have any friction disc at all left.I guess it deteriated and viberated out.I was kinda thinking about trying to make me one out of some kind of material.I may have some gasket material.What else do you think would work.What about somthing like vinyl siding,or somthing like a piece of plastic garbage can. Thanks again...R.M.
R.M. In AL.
10-07-2001 19:06:38
R.M. In AL.
10-07-2001 19:04:48
Dell (WA)
10-06-2001 20:41:07
R M..... .would you believe that there is a cork friction clutch scheme to hold you hydraulic lift lever in position. Tighten it up a little..... Dell
