Order Ford 9N Parts Online
9N runs rough
Randy Dunson
10-07-2001 05:05:05
My 9N runs rough so did tune up, new points, distributor cap, plugs and wires. Still runs rough. While trying to check coil, I found that I only have 2 volts on the coil side of the resistor block but 8 volts (I use and 8 volt battery) on the ignition side. Is this normal or is my resistor block bad? Is there any way to check the coil?
Thanks
bg
10-07-2001 06:58:56
 Re: 9N runs rough in reply to Randy Dunson, 10-07-2001 05:05:05
The best approach would be to get the system cleaned up and use a 6-volt battery. Or do a correct conversion to 12 volt. The 8-volt is a poor compromise solution to other problems.
If and when you get the ignition system straightend out, and it it still runs rough, you only have two other systems to attack:fuel and valves/timing, both of which can be affected by poor compression. Seems to me a systematic diagnosis is in order.
ed-illinois
10-07-2001 05:43:48
sounds like bad resistor or corroded terminals on terminal block.
if it were a bad coil it either wouldn't run at all, or would run great for 1/2 hour or so and then just die.
must be really bad if 8 volts are getting cut to two - perhaps that was the problem when the 8volt battery was installed as well?
ed-illinois
10-07-2001 05:42:57
