2N Pressure Gauge
Ron in Ohio
10-07-2001 15:59:53
Just bought a 2N that runs fine. However, I've noticed that the pressure gauge reads erratically. It does not drop to zero when you shut the engine off; it stays at about 10 psi. When you start the engine, the pressure will rise to approx. 15psi. I'm wondering if I have a bad gauge or should I be worried about a bad oil pump? If I've read the service manual right, the gauge should read between 15-30 psi with the engine running. Is this correct? Any info or help would be greatly appreciated.
Ron
Dell (WA)
10-07-2001 20:47:28
 Re: 2N Pressure Gauge in reply to Ron in Ohio, 10-07-2001 15:59:53
Ron..... .new replacement oilpressure gauges from Ford/New Holland are only about $5. Donna mucka round, replace it. Do the cheep stuff first..... .Dell
Earl(MT)
10-08-2001 08:53:24
 Re: Re: 2N Pressure Gauge in reply to Dell (WA), 10-07-2001 20:47:28
Just a follow up question do you have to bleed the line when you install a new pressure guage?
naw . . . Dell (WA)
10-08-2001 09:47:02
 Re: Re: Re: 2N Pressure Gauge in reply to Earl(MT), 10-08-2001 08:53:24
I never have but you can if'n you want to. It would make it respond a little faster..... .Dell
