Replacing blades on 5' howse shredder---any advice?
8NRay
10-08-2001 21:21:39
My shredder chunked a blade this weekend.
I have bought 2 new blades and bolts to go with.
Any advice on how to remove the old bolts and
replace the blades?
Howse model 500.
Steve IA
10-09-2001 09:15:48
 Re: replacing blades on 5' howse shredder---any advice? in reply to 8NRay, 10-08-2001 21:21:39
I replaced the blades on my 13 yo HYCO which is made by Howse with no trouble at all. I just borrowed a big enough socket and breaker bar from the neighbor, added a cheater to break it loose and unscrewed the nut. Shoulder bolt had to be tapped down to loosen it, but no problem. HTH
Steve 8N 169302
Weedwacker
10-08-2001 21:29:04
Since you bought new bolts I'd cut the old off with a torch or cut off saw. Most of the time they are just too must trouble to unbolt with out heating it with a torch anyway.
Bottom line do what is the easiest for you. You already did a smart thing buying new bolts.
