Photo of my tractor shed
9N'er
10-12-2001 13:40:27
third party image
Recently I posted a note about building and busting my u know what this summer. Last weekend I took this side view picture of the tractor shed as part of the woodshop addition. It shows the hemlock beams, beech braces and the plywood sheathing up (with attic trusses). I am surprised at the look of it, and glad I kept the trees around it. The 850 dug the sono tubes and backfilled them (850 with Sherman backhoe), and excavated the sand and gravel bank to the left that once was where the shed is now. The old tractors get a lot done, and they are now starting to pay for themeslves. I can't imagine hiring out all the jobs that these tractors can do. I think they were a worthwhile investment. 9N'er
Dman
10-14-2001 06:34:25
 Re: photo of my tractor shed in reply to 9N'er, 10-12-2001 13:40:27
Great job 9N'er What may I ask did you use as a fastener between the post and the concrete in the sono tubes?
Simpson brand
10-14-2001 07:42:28
 Re: Re: photo of my tractor shed in reply to Dman, 10-14-2001 06:34:25
I used the Simpson 6x6 post fastener. it's a three part assembly: a main box nailed to the post itself, and within that box a slide in "flat U" piece of 1/8" material. They have enough hole clearance that another piece of 1/8" flat iron (galvanized steel) then is bolted to the anchor bolt set in the concrete tube.
It's a fairly lightweight set-up but I have been assured by a number of builders that they work well. So far, so good. hope this helps.
Eddie S.
10-13-2001 21:05:07
Looks great, Tom! You should be proud!
RON/PA
10-12-2001 15:44:51
You call that a tractor shed????? ??
My wife saw that and now she wants to upgrade the house to look that good, tanx for nuttin buddy!
(It looks GREAT, you should be proud)
Ron
10-12-2001 17:27:35
 Re: Re: photo of my tractor shed in reply to RON/PA, 10-12-2001 15:44:51
yeah, it surprised me too. Funny thing, I have hunch the wife will be shipping me out there for some long night sleeps...and more than on occasion so, it may become my house after-all! 9N'er
Michael Az
10-12-2001 14:14:42
Sure looks good 9N'er. How big is it and were the timbers cut there on your place?-----Michael
9N'er
10-12-2001 17:58:17
 Re: Re: photo of my tractor shed in reply to Michael Az, 10-12-2001 14:14:42
Michael,
The bearing is 25 feet 2 inches (measurement outside of each top plate). Depth is from shop wall to outer post 16 feet. I cantilivered the roof another 4 feet. So, covered area is 25-2 by 20 feet. Ceiling height is just under 10 feet to get the 850 with backhoe inside. The trusses have an upper storage area of 10 feet wide by 20 feet long with a 6-6 collar tie height. Just enough so I don't boink my head on em'. But hanging a light bulb will ensure not only a boinked head but a busted light. And yet, with front loader and backhoe on the 850 one or the other will still protrude from underneath the shed.
yes,
10-12-2001 17:24:36
yes, the posts, beams and braces were cut from the yard/area. I dropped a couple white pines that were 110 years old by the road. They were a hazard with dying branches and tops etc. etc. The butt logs yielded 4/4 board 28-32 inches wide by 12 feet with minimal defect of knots or splitting and butt rot. This place has been used as pasture for 200 years, and I was expecting to break a couple bandsaw blades slicing through old barbed wire and nails. But luck would have it that there were only three old nails placed in there about 20 years ago. They were so rotten they fell apart and only took the edge off the blades. They are handsome boards, and I plan to use them as full width around the perimeter of the shop on edge as wainscoating. They will remain natural, but above them will be a chair rail cap, and then shiplapped pine boards planed smooth and beveled, painted off white. It will look really nice...for a furniture shop. But that's my goal, to have it reflect an early colonial shop/studio so the occasional customer coming in the door will have a feeling of a place back in time. Oh, when those trees hit...WHAMMMMM MMMMM ! bang thud and a bounce. shook the old camp we live in. And oh, the funny part, is the second log in one of the trees is being carved into a bear holding a handplane and a saw in the other hand. A friend is doing it...and a fitting way to use that old tree as a greeting at the front door.
Ed-Illinois
10-12-2001 14:13:27
That Looks Great! A fitting home for a tractor if I ever saw one.
And I agree that the old tractors pay for themselves. When I used to rent a tractor with bush-hog, it was $200.00 for 5 hours and extra insurance, a $50.00 drop off/pick up charge, and $100.00 for every flat tire.
Keep up the good work!
