Hyd. pump noise
arky
10-12-2001 17:29:21
Hey guys my old 47 9N is makeing a
knocking noise when the lift is all the way raised.It does'nt do it any
other time.Only when i have it raised
all the way up.And this problem just
started out of the blue with no warning.What by chance could it be.The noise is comeing from down low
where the pump is located. thanks arky
Al
10-12-2001 20:20:11
 Re: hyd. pump noise in reply to arky, 10-12-2001 17:29:21
Also check the rubber bushing where the pump drive shaft mounts to the engine pulley.
Ken N Tx
10-13-2001 03:45:44
 Re: Re: hyd. pump noise in reply to Al, 10-12-2001 20:20:11
??? What are you talking about??? This is a 9N..
Mikey
10-13-2001 10:06:45
 Re: Re: Re: hyd. pump noise in reply to Ken N Tx, 10-13-2001 03:45:44
I think he means a front mount aux hydraulic pump....
Mikey
9Njoe
10-12-2001 18:28:29
Hi Arky,
I would check the fluid level. If it is too low, when the lift gets up, the pump will be starved for oil.
HTH
Joe
