Low Power
R. Moore
10-15-2001 13:56:04
I just had the engine rebuit and when I tried to bushhog it would almost not pull itself. How do I check the RPMs to make sure it is reaching proper RPMs when throttle is wide open. Also how can I test the engine to find out why the power is low. Thanks Roger
Bob (KY)
10-15-2001 17:20:28
 Re: Low Power in reply to R. Moore, 10-15-2001 13:56:04
Other things to check:
- Assure carb is CLEAN and adjusted correctly.
- Assure govenor is operating and is adjusted correctly. Could have bent linkage and/or levers during rebuild. Check for worn ends / weak springs.
- Assure that items for ignition system tuning are correct and not wore out. Points gapped right(could have slipped), timing adjust, etc.
- Worn distributor parts
Good Luck
Danny in CO
10-15-2001 14:34:58
Check that your plug wires are in the correct order. These old Ns will run fine on olny 2 cylinders but will not have any power. Since you said it was just rebuilt, I would suspect crossed wires. The order is 1243 (or follow the numbers on the distributor cap if front mount dist.).
Danny
Kevin CO
10-15-2001 14:51:05
 Re: Re: Low Power in reply to Danny in CO, 10-15-2001 14:34:58
And the sequnce is counter clockwise on the distributor.
Ed-Illinois
10-15-2001 14:12:47
A wet and dry compression check might point to something regarding low power.
There are aftermarket tachometers from Northern Hydraulics that measure RPM with a lead from a sparkplug wire.
