Order Ford 8N Parts Online
8N Hydraulic oil recommendation
paul 47 8N
10-17-2001 15:53:52
What Hydraulic oil should I use in my 47 8N?
Local TSC store only carries generic 10w20 hydraulic oil. Is this acceptable?
Thanks,
Paul 47 8N
kevin
10-18-2001 11:16:02
 Re: 8N Hydraulic oil recommendation in reply to paul 47 8N, 10-17-2001 15:53:52
At the TSC here, they have the heavy oil in one or 5 gal black container- blue label which specifies that is for 1939-1953 Ford Tractors (or something similar) I think I paid about $28 for 5gal container. Ask 'em.
Ben
10-18-2001 19:14:24
 Re: Re: 8N Hydraulic oil recommendation in reply to kevin, 10-18-2001 11:16:02
I have a 1952 8N ford with distributor on side.
My hydraulic lift is starting to sink as soon as I
stop. What dou you think causes this?
Thanks, Bem
Matt in MO
10-18-2001 07:37:50
Go to your nearest Ford/New Holland dealer and get the 134D trans/hydraulic fluid that they carry. It will come in a big 5 gallon bucket. That is what you need.
Claus
10-17-2001 16:08:04
Nooooo ooooo oo... Do not use hydraulic oil. The transmission and rear end do not like it...Use either of the following 80/90, 90 gear oil, or Ford specification 134D....
Happy Motoring
Claus
Gary
10-19-2001 03:42:32
 Re: Re: 8N Hydraulic oil recommendation in reply to Claus, 10-17-2001 16:08:04
How does the 134D work in the winter?
Claus
10-19-2001 10:10:40
 Re: Re: Re: 8N Hydraulic oil recommendation in reply to Gary, 10-19-2001 03:42:32
Of the 3 I mentioned, 134D is probably the best for cold climate. I run 90W Gear Oil because my lift is a bit leaky with 134D. The heavier oil will now keep my Mower up indefinately. The downside is that in the winter time, it has to heat up a little before it will lift..because it is like syrup..
Happy Motoring
Claus
