Tractor seat
allen
10-17-2001 19:09:12
does anybody know if there is a replacement tractor seat for the 8n made like the late model tractors that does not sit higher than the orignal seat? i have looked at a lot of seats but they sit too high.
Max
10-19-2001 09:51:56
 Re: tractor seat in reply to allen, 10-17-2001 19:09:12
I bolted up a Grammer style suspension seat on my 8N. It bolted right up to the top of the transmission case with no modifications. Seat height was ideal also. I've seen them for sale at Northern Hydraulics for about $100. Sure makes the ol'8N smooth ridin when mowing or disking.
jon
10-18-2001 02:02:12
Mine had a later model seat on it when I bought it (the blue one) & it works fine. Not sure if it sits any higher than the original since I've never tried one but seems to be about the height it should be & bolts right up to original holes.
bg
10-17-2001 20:43:08
If you're looking for a shock-cushioned seat, you probably won't find one that sits low, unless you can find a Rest-O-Ride from a 60's model. You can use a high-back, foam lawnmower seat that will bolt right onto the original seat leaf spring.
