Can i convert a single wire genorator to a 3 wire regulator?
Robert
10-18-2001 14:01:23
can i convert a single wire genorator to a 3 wire regulator -rather than using a cutout
i have a vr950 regulator but it has 3 wires
batt.
arm.
fld.
i dont know if this will work with this regulator any help is appreciated thanks alot Robert
Craig
10-18-2001 19:11:35
 Re: can i convert a single wire genorator to a 3 wire regulator? in reply to Robert, 10-18-2001 14:01:23
There used to be available a kit with a regulator and resistor kit to be used to convert a 3rd brush type generator with cutout to a regulator. Check with a starter/generator repair shop. Other wise a auto parts place that carries the "Standard Ignition" brand of products will have it listed in the buyers guide catalog. However, the counter person will not know what you are talking about or know where to look it up.
That electronic unit someone below linked to sure does look like a neat idea however.
Claus
10-18-2001 14:13:15
The field on a single wire generator is controlled by the third brush. On a 2 brush generator the field current is controlled by the voltage regulator. I do not know what a VR950 is or what it is out of...All voltage regulators are not created equal. Even the 8N has 2 different types. The A and the B. The difference is the setting of the current coil. The A is a 11.5 amp unit and the B is a 20 amp unit.... One could use the A on a B system but the current would be limited to 11.5 amps. If one were to use a B unit on an A, and since that current coil is set to 20 amps, it could ruin the generator. 75 watts vs. 140 watts.
Happy Motoring
Claus
Robert
10-18-2001 14:21:08
 Re: Re: can i convert a single wire genorator to a 3 wire regulator? in reply to Claus, 10-18-2001 14:13:15
the vr950 regulator i have is what is called for for the 8n ford but i dont have the field wire to hook up. do you think i can hook up the bat and arm wires
and put the fld to the case?
if not then how should i hook the wires
positive ground is verry confusing to me??? thanks claus
Claus
10-18-2001 14:44:29
 Re: Re: Re: can i convert a single wire genorator to a 3 wire regulator? in reply to Robert, 10-18-2001 14:21:08
You cannot use a 8N VR with a single wire generator. The only thing you can do with it is use the cutout relay in the voltage regulator instead of the traditional cutout relay. This of course would not give you regulation. If you really want regulation then get yourself a 3 wire generator. There is also an outfit that has a cutout relay with a regulator built in...
Happy Motoring
Claus
Robert
10-18-2001 14:52:40
 Re: Re: Re: Re: can i convert a single wire genorator to a 3 wire regulator? in reply to Claus, 10-18-2001 14:44:29
o.k.
thanks claus enjoyed your site thank`s, Robert
robert
10-18-2001 14:42:44
the regulator i have is a 12 amp
and the generator is adjustable so i think i can make it work out but what do i do with the fld. wire?
just leave it unhooked?
