Lightswitch
R.M. In Al.
10-21-2001 16:31:02
I replaced my lightswitch with one from Walmart a few months ago.I noticed today that its not fused. Would it be best to install an inline fuse holder between the switch and the lights,or between the switch and the power source(Batt) or would it really matter.Im thinking between the power source and the switch.Thanks Fellas... R.M. In Al.
Dell (WA)
10-21-2001 22:02:19
 Re: Lightswitch in reply to R.M. In Al., 10-21-2001 16:31:02
The "original" N-Tractor light switch had a "built-in" fuse. Not that expensive and solves your problems..... .....Dell
terry
10-21-2001 20:03:26
put the fuse as close to the source(bat) as posible.The fuse will protect anything after it(wire, switch,wire after the switch and lites.)
Paul N. MI
10-21-2001 19:31:13
Whatever is most acssessable if you ever have to replace the fuse. That would be my guess!
