Order Ford 8N Parts Online
Gear Grease for 1952 8N
Rick Ramirez
10-22-2001 15:48:04
What is the recommended type and weight of Gear Grease that should be used in the transmission of a 1952 8N?
All responses will be appreciated.
Thanks,
Rick
Barnstormer
10-23-2001 04:25:19
 Re: Gear Grease for 1952 8N in reply to Rick Ramirez, 10-22-2001 15:48:04
If you have rebuilt your system, the "new stuff" should work and will not be "sleepy" during a winter start-up. If you are just replacing old oil, without any rebuild, I would use 80w90 gear oil.
For myself, I use the 80w90 either way.
JimNC
10-22-2001 16:55:10
Ford New Holland M2C134D is recommended, but 80w90 will work fine too.
