Order Ford 8N Parts Online
8N Gov./Throttle Linkage Adjustment
Radley
10-24-2001 20:28:37
Does anyone have a fool proof step by step on setting up the throttle and governor linkage/springs and rods correctly in the order they should be adjusted. I just rebuilt my governor which was worn and replaced all the springs (Throttle rod tension, governor arm and throttle return) along with the quadrant plate to eliminate all possibilities (Typical back yarder-replace all) Now I would like to set up the linkage so the governor kicks in before the rpms die down. So far it does not work and requires more throttle to keep up rpms. What to do??? I assembled the governor as the books said to do and made sure I had .22 to .23 travel for the fork inside. I have the service manual,operator manual and the F0-4 shop bulletin. I would appreciate a layman expert's, step by step to make sure I set it up right and in the right order to eliminate Q? on proper sequence of adjustment.
Radley
10-26-2001 17:42:19
 Re: 8N Gov./Throttle Linkage Adjustment in reply to Radley, 10-24-2001 20:28:37
I know I was long winded, Sorry!!, but doesn't anybody want to take a stab at this???
