Hydraulic lift
alan/norway il
10-25-2001 20:05:53
question, my lift will lift my 60 inch mowing deck but when i put my rear plow blade on it will only raise it about 1to2 inches off the ground
like i said with my mowing deck or when i use the boom i can raise the lift 2 to 3 ft. is the blade to heavy its about 6 ft. long.
Dell (WA)
10-25-2001 20:34:14
 Re: hydraulic lift in reply to alan/norway il, 10-25-2001 20:05:53
Alan..... ..quick check. See if you can lift your mower with your boom, then see if'n you can lift your backblade. Should be able to lift eather. If'n you can't you've got hydraulic pressure problems. Report back on your success and we'll try to help you more if'n not good news..... .Dell
