I ordered all the back issues of the N-newsletter that contained live hydraulic articles, hoping to find a magic pill as it were. Nope. Just a couple of articles on mounting external cylinders to the hitch arms. So back to the drawing board I went, having read up on hydraulic systems. I think I finally figured it out. It doesn't screw the pump up, and is completely reversable. The intake valve for the pump body has two ports in it directly across from one another, for feeding both banks of the pump cylinders. It is controlled with a tapered insert (I'll call it a valve) sliding back to allow fluid in, and sliding forward, to block it off. This motion is caused by the control rod. Ok, what I propose is to use that intake valve, but in a very different matter, setting it up as an open center valve, with a live hydraulic pump feeding it at all times. Instead of having both ports of the intake valve draw fluid, I will have fluid sent across them. With one side being pressurized, and the other receiving the pressurized fluid. It will be exactly like the open center spool valve used to control a front end loader lift cylinder. In the neutral position, fluid would be vented out the front of the intake valve assembly, in reverse of how fluid flows in the oem unit. To do this, I would install the intake valve spool backwards. It would have a groove cut into it that would run fluid across the two ports when the valve spool is pushed back by the control arm, and bleed the fluid out through the front in the neutral position. I've spent a fair bit of time measuring this, and it should work. It may involve a little cutting back of the intake valve cylinder to help fluid flow in the neutral position. To make this work, I need pressurized fluid coming in from one side, and going to the lift cylinder on the other. This is easily done by taking the heads off and installing them backwards. This blinds the pump cylinder intake and exhaust passages. By drilling and tapping the head on one side, I can attach the pressurized line from the live pump to that intake port of the intake valve assembly. Then on the other side, I can drill and tap at both intake and exhaust, joining them with an external line. This allows the pressurized fluid that has passed through the modified intake valve to lift the hitch. You could also grind a grove in the head to create a passage instead of attaching an external line. This modification would only affect the lift assembly prior to the four pump cylinders. So things like the exhaust valves and check valve and safety valve would all operate unchanged. I believe this modification will work, and I'll be starting the modifications shortly on my old pump body. No machine shop will be needed, as all the modifications can be done at home with a drill being the only power tool required. I can cut the intake valve spool by chucking it into the drill, and holding a stone against it as it spins. Not high tech, but completely effective. The pump I'm going to use is the gear or vane type pump already on my loader frame. The pump does not leak, so once it's been bled out it shouldn't lose prime. Since it's inline with my crankshaft, it doesn't have to draw fluid up high, which helps ensure I won't have cavitation problems. I'll probably switch to the newer fluid when I do this job. I'm getting all mightly sick of cavitating the pump in cold weather with the thick oil. Leakage losses in the pump system due to the thinner fluid shouldn't matter since the gear pump is so much more pump then the oem scotch yoke unit. I can see a possible need for a flow restrictor or diverter device to the hitch. Otherwise, I could end up with a unit that throws impliments into the air, instead of lifting them. Since I'm going to be using the loader pump, and mounting it with a loader frame (so I can use the loader at times), I'll also be mounting the loader type controls. Simple enough matter to install the flow diverter there, between the loader controls and the three point hitch controls. Being a military type, who loves redundant systems, I will also probably tap in a line directly to the 3 point lift cylinder from the loader controls. For the sole purpose of being able to lift with the loader control if I wish. Snow plowing was far to exciting this winter, and I want more then one way to get the blade up, now, so I can shoot back across the road and out of the way. True, this secondary lift would have no quadrant controls, but that's ok by me. Comments, critisizm, questions and advice are being sought by me on this. I think it'll work, but if you don't I'd like to know why.
