Order Ford 8N Parts Online
8N Drawbars assemblies
68 Mag
10-29-2001 13:05:06
This is something I'm going to need as soon as I get my 8N running properly, because I have several dead trees and stumps to move. Now, I remember a while back, someone posted a picture of a drawbar, that went up under the tractor and had one hole in the rear. It might have been a Sears drawbar. I searched the archives and couldnt find it. I was wondering if anyone had this photo, or any information on this type drawbar, because this drawbar didnt interfere with the 3 point, as in I could have the drawbar on, and still use a 3 point implement.
Leroy
10-30-2001 18:33:16
 Re: 8N Drawbars assemblies in reply to 68 Mag, 10-29-2001 13:05:06
You need the after market type, orignal Ford mounted same way underneeth but did not have the part that mounted around the PTO, they used the cross drawbar on the 3 point arms with the stay straps
Jim
10-29-2001 14:41:29
Again look at John's web site - besides the foot throttle control - last time I looked he had a drawbar for sale also. Jim
68 Mag
10-29-2001 13:23:25
 Re: Re: 8N Drawbars assemblies in reply to Jim CT, 10-29-2001 13:20:20
So, 8N's didnt have factory drawbars? If I want one, I have to get aftermarket? Ford didnt make 8N drawbars?
RWK in WI
10-29-2001 16:46:27
 Re: Re: Re: 8N Drawbars assemblies in reply to 68 Mag, 10-29-2001 13:23:25
My Ford / N H dealer gave me a complete unit for my 860 when he discovered it had been taken off when traded in before I bought it.
All parts had F / NH part numbers on them. Ford 8N sales brochure of 52 listed them as availabe both factory or dealer installed.
Found a picture- 68 Mag
10-29-2001 13:26:26
third party image
I want a drawbar like in this picture. Are they made?
SteveS2 (WI)
10-30-2001 08:02:38
 Re: Re: Re: Re: 8N Drawbars assemblies in reply to Found a picture- 68 Mag, 10-29-2001 13:26:26
I purchased one of these last night at Fleet Farm; $61.00 out the door. Hope to see how well it works this weekend.
Steve
Tom-Pa
10-29-2001 13:38:38
What you found is the after market type drawbar that can be used on the 8N, NAA(jubilee), and hundred series Ford tractors. It will not fit a 9N/2N as they do not have the bosses for mounting the bolts under the tractor. The 8N and later tractors were made to have a heavier area here so they could drill out for the bolt holes...
Good luck,
Tom-Pa
68 Mag
10-29-2001 13:40:28
 Re: Re: Re: Re: Re: 8N Drawbars assemblies in reply to Tom-Pa, 10-29-2001 13:38:38
Is there any type of drawbar that can be mounted without drilling new holes in the N?
don b
10-29-2001 14:02:06
 Re: Re: Re: Re: Re: Re: 8N Drawbars assemblies in reply to 68 Mag, 10-29-2001 13:40:28
The one pictured in the above post is what you need for the 8n.It mounts to the existing holes on the bottom of your 8n housing. don
