Order Ford 8N Parts Online
8N Toolboxes
68 Mag
10-29-2001 13:21:40
Well, first off, get ready, for my plauge of questions is about to begin. Now, the question- on our Farmall Super A, there is a tool box that mounts under the seat. I was wondering if the 8N had any type of tool box, and where it was located. I believe mine is devoid of any tool box, unless I'm just not looking in the correct place. I looked under the hood, above the battery, because I had hear 9N tool boxes were in there. I have no tool box under the hood, or under the seat.
llamas
10-30-2001 08:06:40
 Re: 8N Toolboxes in reply to 68 Mag, 10-29-2001 13:21:40
Dennis Carpenter (www.dennis-carpenter.com) will sell you a brand-new 8N toolbox, indistinguishable (to my untrained eye) from the original, painted 8N red, for $24.50.
There's plenty of 12 volt batteries available which will fit the stock battery tray without having to remove the toolbox.
HTH
llater,
llamas
Ed Gooding (VA)
10-30-2001 03:28:53
Here's four views of the 8N toolbox, so you'll be able to easily identify one when you find it:
third party image
Here's how a restored one looks with the lid up:
third party image
Hope this helps..... ..... Ed
'52 8N475798
Patrick/OR/n-tiques.com
10-29-2001 20:08:44
One of my 8Ns has a 12V system and the tool box. Fits just fine! If you would like, I'll photograh it and send it to you by email.
Best of luck!
Patrick
www.n-tiques.com
68 Mag
10-30-2001 09:31:03
 Re: Re: 8N Toolboxes in reply to Patrick/OR/n-tiques.com, 10-29-2001 20:08:44
That would be great. What battery do you use, is it smaller than a standard car/ truck battery?
Stuart K
10-29-2001 18:15:44
As others have said it is by the battery. If your tractor has a 12v conversion they are usually removed to fit the bigger 12v battery. StuK
68 Mag
10-29-2001 18:55:10
 Re: Re: 8N Toolboxes in reply to Stuart K, 10-29-2001 18:15:44
Well, that would explain it. It has had a 12 volt conversion. Do they make any type tool box for them, that is either small enough to fit with the 12 volt battery, or one that mounts somewhere else? I saw one floor board for a Jubilee with a tool box under it.
Stuart K
10-30-2001 20:49:09
 Re: Re: Re: 8N Toolboxes in reply to 68 Mag, 10-29-2001 18:55:10
Can't say I know of one ( I'm pretty new to 'N's and tractors in general.) Dennis Carpenter makes reproductions of the original and originals can still be had in the classified or ebay etc. StuK
Tom-Pa
10-29-2001 13:41:51
The 9N/2N's had a toolbox that was mounted on the side of the battery box down low. The 8N had their box above and behind the battery. It had a sloped bottom to accomodate the instrument panel.
Where are you located at? I know where one or two are near me.
Tom-Pa
68 Mag
10-29-2001 13:43:24
 Re: Re: 8N Toolboxes in reply to Tom-Pa, 10-29-2001 13:41:51
I'm in western TN.
under the hood by battery
10-29-2001 13:29:59
Under the hood by battery
