Order Ford 9N Parts Online
9N re-wired??
AndyZ
10-29-2001 20:49:20
Well, I finally got hold of a 41 9N and having a ball bringing her back among the healthy. Noticed something that I need advice on:
The battery is wired NEG to GND. All the manuals I have gotten say POS to GND. A previous owner must have re-wired (?) the thing sometime in the past. How can I tell if it was done right, or if it's running but malfunctioning? Still has a Generator, ammeter, and 6-volt ignition.
Dell (WA)
10-29-2001 22:39:22
 Re: 9N re-wired?? in reply to AndyZ, 10-29-2001 20:49:20
Andy..... ...The only wiring difference between POSITIVE ground and NEGATIVE ground is the battery wiring. And then re-polarize your generator/regulator per I&T FO-4 manual before you start up after changeing. I will not tell you how to re-polarize because I always have to look it up, you can do it too..... ...Dell
AndyZ
10-31-2001 06:59:08
 Re: Re: 9N re-wired?? in reply to Dell (WA), 10-29-2001 22:39:22
Thank you very much. That is exactly the info I was looking for.
-andy-
