Solutions to engine knock?
Adam
10-30-2001 12:35:24
I live in the Pacific NW, and with the advent of cooler weather, my 9N has picked up a knock in the engine. I just finished overhauling the carb, tuned the ignition,and gave it the semi-annual oil change. The tractor had not been run for about a month after being used weekly all summer. It is in the mid-30's to mid-50's now.
The knock is very loud, and sounds like it's coming from the #2 cylinder area. There has been no change in oil pressure, and it still runs around 40 psi cold. The gage is new this year, so I think it is close to true. I tried 5W-30, hoping to get a little more pump-ability with the thinner cold oil. No luck. Still knocks. I only run it for 30 seconds at a time.
Does anyone have any suggestions, shy of a rebuild? Compression is within spec, and it runs like a dream otherwise. The knock appeared suddenly, the first time she was started after sitting for a month in the barn.
Thanks in advance for your help.
Larry Hollar
11-01-2001 13:53:18
 Re: Solutions to engine knock? in reply to Adam, 10-30-2001 12:35:24
Remove head and turn crank. See if a sleeve is loose and moving in the block. That's where mine was.
Larry Hollar
11-01-2001 13:52:15
Remove head and turn crank. See if a sleeve is loose and moving in the head. That's where mine was.
Big Mike
10-30-2001 20:50:33
While you have the head off also check the deck height. Roll the crank and bring each piston to TDC, measure from deck to piston. Could have been a leaky headgasket and bent a rod or damaged a wristpin or piston from hydraulic lock.....Big Mike
Terry
10-30-2001 17:53:32
Adam, before you tear down your engine, first pull the head off and check for carbon. I had an engine knock in by 8n and I just jumped in and tore down the engine. I couldn't find anything wrong except for some carbon on the top of the piston. I mow weekly with mine, and it runs a steady rpm. If I had only pulled the head first, I would have saved alot of work. I now load the engine down from time to time to rid it of any carbon. Terry.
Steve W
10-30-2001 14:10:15
A mechanics stethescope will help you figure it out.....I'd be willing to bet that it is actually a leak in your exhaust manifold.....ususally knocks develope over a period of time....start it cold, and feel aound the manifold for a leak...
Take Care
Steve
