Thanks! You already answered my hyd. control arm question.
Roger
10-30-2001 16:55:19
My father-in-law recently gave me a 1948 8N. I just pulled the hydraulic control unit because the touch control lever was out of whack. The main problem was that the position control pin was warn and bent. However, I also noticed a slight curve in the end of the control arm and was suspicious it should be straight.
A quick search found a message posted by Roger on August 01, 2000 that asked about the control arm. Thanks to ZANE, I now know for sure that it should be straight.
This leaves just one question. Is there another Roger out there that had the same problem. Or do I have Alzheimer's real bad, and I made that post on 8/1/00 even though I don't remember having my tractor back then! :) :)
RussJ
10-30-2001 17:33:12
 Re: Thanks! You already answered my hyd. control arm question. in reply to Roger, 10-30-2001 16:55:19
Try Ginko- biloba. Its supposed to help memory. I want to try it but every time I go to the store I forget to buy some.
