What to look for??
rad
11-04-2001 18:04:14
Can someone please help!
I have rebuilt my governor(delux kit), replaced all springs,quadrant plate, set the tension on the gov. spring as the ITO book says, yet I still cannot get the governor to react to change in load. What am I missing. It acts as if I have connected the throttle direct to carb., yet I checked and the linkage is connected correctly??
Please set me straight on what I should see and what to check for. I must be overlooking something, but throwing money at it does not seem to help.
Bob (KY)
11-04-2001 21:39:58
 Re: What to look for?? in reply to rad, 11-04-2001 18:04:14
MAY NOT be the govenor.
Could be any/all of the following:
- Spring ends of gov linkage worn. Lot of end slop will not allow gov to function properly
- COMPLETE ignition tuneup
- COMPLETE and THOROUGH cleaning and CORRECT adjust of carb
- COMPLETE overhaul of distributor
Larry
11-04-2001 18:27:40
Rad,
I entered a rather lengthy discription of how to approach your problem, but the E-mail was returned stating that your address was invalid, user unknown.
If you'll contact me at landcranch@AOL I'll forward a copy to you.
Regards,
L and C Ranch
Larry
