Tools and help from the experts
rbell
11-05-2001 06:45:18
I picked up three tools Sat. at a large "junk" sale. One is an s shaped wrench with Fordson on it. Looks like a double ended lug wrench, but smaller. Another is a FORD monkey wrench (not a pipe wrench). Ford script, about 12 inches long, but it has a square tang on the handle end. Any idea what thats for? The third is a plow wrench, is marked at 1 inch intervals, with a 3 and a 9 raised numeral. On the reverse side it has a circle with an "M" inside and the number 5 beside that. $3 for the three. Did I do good?
Thanks
Farmer Tim *8N15513*
11-06-2001 17:17:42
 Re: tools and help from the experts in reply to rbell, 11-05-2001 06:45:18
I think the monkey wrench was for the Model T & A's if it has the tang on the end of the handle. The original N tractor adjustable wrench has no tang but a rounded handle end. Not sure what the tang was used for...anybody??? You got a very good deal if nothing else for the plow wrench especially if it has the FORD logo not FoMoCo and/or is good condition. I'm learning more about the N tools myself and came across this web page dedicated to Ford Tool Collectors- you can check out the NAFTCO web site yourself for all the info. They may have that Fordson wrench...good luck!
Tom
11-05-2001 12:00:26
How many pounds torque do I tighten my axle nut to or does it matter. What tool do I need. My wheel fell OFF!!!!! !!!
Don (NC)
11-05-2001 07:51:14
If the plow wrench has the Ford script or FoMoCo logos, then you have done very well indeed. If not, you have one of the generic versions, which usually sell for $10-15 on ebay. The Moore Drop Forge company made the same wrench for Ferguson and Massey Harris and a generic version with no tractor co name. (The M is Moore's logo.) Still not a bad deal.
The adjustable would usually bring $5-10 and the Fordson, depends on which one it is, condition, etc., but probably $10 up minimum.
Not bad for $3...
Does this look like your Fordson?? Don (NC)
11-05-2001 07:55:19
 Re: Re: tools and help from the experts in reply to Don (NC), 11-05-2001 07:51:14
See the ebay link below
rbell
11-05-2001 08:59:43
 Re: Re: Re: tools and help from the experts in reply to Does this look like your Fordson?? Don (NC), 11-05-2001 07:55:19
Thats the one Don, even down to the number! It is in better shape than the plow wrench. I am going to try some rust remover to clean out the writing on the plow wrench and see if it says Ford.
Thanks, to all
bg
11-05-2001 07:08:06
For $3.00 you ask if you done good(did well)? The wrench with the square tang on the end was designed to remove a square-recessed plug (from the differential?)on the Model T or A automobile. The tractor wrench did not have the square tang on the end. I guess you could grind it off. The Fordson wrench is a Fordson wrench and the plow wrench usually goes for anywhere between $20-40 on ebay.
