Order Ford 8N Parts Online
Shift Knof on 8N.
roger gehring
11-06-2001 12:31:15
My 8N is a 1948. They did not have a black knob on the shifter. Does anyone have an idea to put one on short of cutting off the shifter? Thank you.
Roger S
11-07-2001 10:00:43
 Re: Shift Knof on 8N. in reply to roger gehring, 11-06-2001 12:31:15
How about drilling out the shift knob until it fits on the shifter. Then put a bunch of epoxy, like J B Weld, into the hole in the knob and stick it on the shifter.
If you ever need to get it off, a chisel would probably work.
bg
11-06-2001 13:13:40
Go to the boneyard and get a later model shifter and swap it out. You could also grind the knob off the current shifter and thread the shaft for the knob, but it would easier to swap it out.
ALP
11-06-2001 19:28:07
 Re: Re: Shift Knof on 8N. in reply to bg, 11-06-2001 13:13:40
No offense "bg", but why bother? Just leave the ball on and use it that way.
bg
11-07-2001 08:52:08
 Re: Re: Re: Shift Knof on 8N. in reply to ALP, 11-06-2001 19:28:07
Hey, he was the one who asked. I just try to help 8^)
68 Mag
11-06-2001 12:58:06
If I understand John Smith's page correctly, there should be a cast knob on the shifter, and it's a part of the shift lever. They didnt put plastic ones on them until 1950. I'm not sure, so hopefully someone who knows more than me can answer your question definately.
