Order Ford 8N Parts Online
Numbers on an 8N
68 Mag
11-06-2001 12:55:26
Ok, I have yet another question. On the left rear axle housing of my 8N is the number 8N-4D1282. Can anyone tell me what this means? Is it just a part number, or does it bear some significance as to when my N may have been manufactured?
Thanks,
68 Mag
Larry 8N75381
11-06-2001 17:10:08
 Re: Numbers on an 8N in reply to 68 Mag, 11-06-2001 12:55:26
Something is not right - OR at least it does not match up with my parts books (original 1949 copy).
The LH axle trumpet part number for an 8N is 8N 4011-A. Howver the RH axle trumpet for the 9N and 2N is 4012, precisely 9N 4012-B and 2N 4012-A2 respectively. I can see the 0 looking like a D, and the B looking like an 8, but the 8N beginning is what has me thrown.
Take a look at my Photopoint album linked below and see if that helps you.
Regards,
Larry
Ed-Illinois
11-06-2001 13:39:29
Look at the starter housing - there should be a casting date in the form of a letter and numbers.
If memory serves the letter equates to a month (jan=A, feb=B, etc), the next two numbers the date, and the final number the last digit of the year it was cast.
Since engines were often swapped between tractors, this is generally a better way to date your tractor.
I also belive that the same sort of casting ID is located on the rear axle, right side, facing forward.
