Wheel weights.
Rusty 2N
11-06-2001 19:26:51
Now that I've got new rims & tires on Tor I'm not to interested in pouring any calcium any where near them. I'm wondering how many LBS does one hang back there. I'm changing the debander discs on the Yeilder no till drill at work & acording to my back it wouldn't take to many of these old discs to add up to some serious weight. I should be able to build a hanger. So I was just wondering what the agerage weight was. By the way, there is a bunch of information in the archives. Could get lost in there. Like an Ncyclopedia. TIA Rusty 2N
Dell (WA)
11-06-2001 21:45:13
 Re: Wheel weights. in reply to Rusty 2N, 11-06-2001 19:26:51
Rusty..... ...generally speaking, CaCl in N-reartires for traction adds about 350# ea tire.
If'n I needed extra weight for traction, and wanted to use "water", I'd use some RV antifreeze (its non-poisionous to dogs if you get leaks) to prevent the water from freezing. You don't need to prevent down to -35*, 10 or 15 will do just fine and if'n you did decide that you just had to tractor in below zero weather, the antifreeze would just be slushy..... ..Dell
