Low RPM miss
RussJ
11-07-2001 09:55:08
Im chasing a low speed miss I cant figure out.I think its carburetion because I get little difference when I adjust the idle jet or mixture needle. I just replaced the manifold with a new one. Could I have a small leak between intake/exhaust ports at the head? I dont hear one.High speed under load runs fine. It was running fine before I replaced the manifold. Plugs/wires,points are all new. Help- I like when this thing purs like a kitten.
Fessman
11-07-2001 18:45:52
 Re: Low RPM miss in reply to RussJ, 11-07-2001 09:55:08
Russ,
I was experiencing a miss under load and some one suggested changing the bushings in the distributor. (I have a front mount distributor) That seemed to take care of 90% of the problem.
Fessman
9Njoe
11-07-2001 11:21:41
Russ,
I had a similar problem with my N. Low RPM miss, Idle jet has no effect. High speed OK, Low power.
It turned out that there were bad valve seats that were affecting the vacuum at the carb and screwing up the mixture. I ended up rebuilding my engine completely.
To determine if this is your problem, do a compression check. It will be obvious if that is the problem. Also the manifold can be drilled out and a vacuum guage can be attached if you are so inclined. I didnt do this but if my problems persisted, I would have.
Another trick to determine if there is an intake leak is to spray the manifold with carb cleaner with the engine running and see if that affects the miss. If it does, then you have found the problem.
I went through all of the above but the valves were my problem. The rotators froze and the exhaust valves and seats burned and the compression went away. I hope that this is not the problem because it is a pain to fix.
Good luck and let us know how you make out
Joe
RussJ
11-07-2001 11:38:23
 Re: Re: Low RPM miss in reply to 9Njoe, 11-07-2001 11:21:41
Thanks for the reply. I hope thats not the problem. I do not have any type of loss of power. In fact the motor seems as strong as ever. I havent done a compression check lately. I'll try that and see.
