Order Ford 8N Parts Online
8N PTO pumps?
68 Mag
11-07-2001 13:02:23
Ok, here's the deal. I've heard of a pump that runs off of the PTO for loaders and large remote hydraulic uses. My question is, could I find a pump that I hook to my PTO and use to spray water or a similar liquid through a single hose? About how much would one of these cost? I ask because ever since the accident, I'm horrified of another field fire. I want to make a small trailer, with a 100/ 200 gallon tank on it, and 100 or so feet of hose to use if there ever was another field fire.
Thanks,
68 Mag
Ed-Illinois
11-07-2001 14:27:50
 Re: 8N PTO pumps? in reply to 68 Mag, 11-07-2001 13:02:23
I think the link below might be what you need - Northern Tool has liquid pumps for the PTO shaft.
68 Mag
11-07-2001 17:31:46
 Re: Re: 8N PTO pumps? in reply to Ed-Illinois, 11-07-2001 14:27:50
Wow, I just picked my jaw up off the floor. I cant spend more than 70 for a pmup, and really it'd be best under 50. I may just have to find another way...
Larry 8N75381
11-07-2001 13:55:21
In one of the buildings on the farm I bought, there was a pump that had a PTO coupling on it. Looked like it was 1-3/8" 6-spline. Can't remember if it was vane or roller style.
You should be able to easily hook up such a rig from the selection of components at your local farm supply store - like TSC, etc. You would want to use components ment for spraying insecticides/etc. that are mixed with water. However, I just looked in an ole catalog, and pumps are not cheap. Over $60 for just 7 GPM to $319 for 82 GPM. For $220 you could get pump and gas engine combo. You pays your money and takes your choice. I'd lean towards the self driven pump engine combo since it would not need to be hooked up to the PTO and you hook it to anything that could pull a trailer.
My $0.02!
Larry
68 Mag
11-07-2001 14:27:10
 Re: Re: 8N PTO pumps? in reply to Larry 8N75381, 11-07-2001 13:55:21
Whoa, I had no idea pumps were so expensive. This may need to be built from scrapyard parts...
