Order Ford 9N Parts Online
9N battery problems
Phil Jackson
11-11-2001 09:40:17
Have a 9n that I have just replaced a battery with 2 dead cells. I go to start the tractor 3 days later after only moving it quickly the day of the new battery installation and it is completely dead! What on earth would cause such a discharge while not in use and discharge to the point of not even attempting to turn over? have the battery(12v) on slow charge and I will see how that charges.
Quickdraw
11-12-2001 08:17:03
 Re: 9N battery problems in reply to Phil Jackson, 11-11-2001 09:40:17
Had exactly the same problem on my 9N 12 volt conversion, I found that the insulation had come off the wire running through the metal loops on the back of the amp meter. Between the rust on the loops & the meter not being grounded very well the short just slowly drained the battery.
HRS
11-11-2001 13:30:54
Is it original, or one of those converted hoopies? If it is still 6V, then check for a short or a sticking cutout. If somebody wrecked it by converting it to 12V, then good luck.
bj/8N/mt
11-11-2001 10:35:30
If you left the key on and if the points were closed three days is plenty of time to run down even a new battery. The cut out is also worth looking at.
Your mileage may vary
Canadianiner
11-11-2001 09:56:55
One possibility is the cutout for the generator isn't cutting out and the battery is discharging through the generator.
