Gas leak from carb
Sarah
11-11-2001 11:55:04
I recently took apart and checked the carb on my 9N and it looked clean and I checked it against the recommended float distance etc. when reinstalled however, it leaks from the air intake which it didn't before i took it off. it's been tightened as much as possible, is there an adjustment i should be making to lessen the amount of gas in carb. It runs great, but i don't want to lose the gas! Thanks
PCC-AL
11-11-2001 12:37:11
 Re: Gas leak from carb in reply to Sarah, 11-11-2001 11:55:04
My 8N carb did exactly the same thing when I cleaned it recently. I took it all apart a second time and put it back together. It didn't leak after that. I don't know why as I really didn't change anything. I am pretty sure my problem was the float needle. I must have unstuck it when I took the carb apart again. Good luck.
