Order Ford 9N Parts Online
9N Carburator Misery
Andy
11-11-2001 14:31:45
Tractor running great---suddenly stalls--suspect carburator--Installed new carb kit and now trys to start but cannot keep running. Have tried everything on settings. Will not pull gas into chamber unless full choke. Does anyone have any ideas Incidently also installed new points,condensor,dist cap, and coil.
Jim(FL)
11-12-2001 06:05:42
 Re: 9N Carburator Misery in reply to Andy, 11-11-2001 14:31:45
Andy, Baesd on this original description of your problem. I'm not really convinced that the carb (fuel) was your problem. A blocked fuel supply line would give a "Tractor running great---suddenly stalls" so check all three inline filter screens and the supply line. If the fuel supply is OK then I would suspect something electrical. Check the strength of your spark.
Jim
ED-Illinois
11-11-2001 14:39:05
How are the manifold gaskets?
How is fuel flow at the carb?
Have you checked the screens for debris?
Andy
11-11-2001 16:35:58
 Re: Re: 9N Carburator Misery in reply to ED-Illinois, 11-11-2001 14:39:05
Gas flow is good, no debris.. Compression is excellent .Will check manifold gasket,Do you know of a way to check leaking manifold without engine running? Can it be checked by cranking? .Thks for suggestion.
Dell (WA)
11-11-2001 17:41:37
 Re: Re: Re: 9N Carburator Misery in reply to Andy, 11-11-2001 16:35:58
Andy..... ..I'd spray WD-40 (long nozzle) everywhere there are manifold and carburator gaskets. The WD-40 will fill up anyleaks and alow the engine to suck gas up thru the carb..... ..Dell
ED-Illinois
11-11-2001 21:08:36
 Re: Re: Re: Re: 9N Carburator Misery in reply to Dell (WA), 11-11-2001 17:41:37
What Dell Said - don't forget the gasket between the carb and manifold too.
