Does anyone have a grader blade under their tractor?
Roger S
11-12-2001 22:56:15
I'm thinking of adding a grader blade to my 8N. That is, a blade mounted under the tractor not behind it.
Does anyone have this, or is it a silly idea? Any information would be appreciated.
iluv8ns
11-13-2001 20:16:50
 Re: Does anyone have a grader blade under their tractor? in reply to Roger S, 11-12-2001 22:56:15
where can you get a front pusher or whatever that is in the picture...would be great for moving snow!!
Errin OH
11-13-2001 08:33:50
I don't, but it looks interesting. Link below is past post from Ed Gooding (Belly Blade)
Roger S
11-13-2001 15:27:01
 Re: Re: Does anyone have a grader blade under their tractor? in reply to Errin OH, 11-13-2001 08:33:50
Thanks for the link Errin.
That looks like quite the piece of equipment - more than I need.
But, it doesn't look like it allows you to change the angle of the blade.
bg
11-13-2001 05:49:03
It's a good idea when compared to trying to do a decent job of grading with a back blade. It's pretty common to see Farmall Super A's with a makeshift blade mounted on the front(belly) cultivator drawbars. Haven't seen too many Fords with a mid-mount grader. Probably because it would be a pain to devise a decent mounting system that would allow the blade to pivot, swing and pitch to the different angles needed to distribute the dirt or gravel correctly. I hate grading with a rear-mount blade because the short wheelbase of the N tends to multiply the washboard effect.
don t. - 9n180179
11-13-2001 08:20:52
 Re: Re: Does anyone have a grader blade under their tractor? in reply to bg, 11-13-2001 05:49:03
"the short wheelbase of the N tends to multiply the washboard effect"....been doing driveway grading and noticed that washboard thing you described. Try as I have, aint been able to smooth it out. The washboard is maybe 3-4 inches tall. Don't really know its there except when the headlights shine accross them. Do I "need more pratice" grading or is there something im doing wrong?? All I have is a rear blade, no box blade.
Regards...don t. - 9n180179
Al(Ca)
11-13-2001 09:46:29
 Re: Re: Re: Does anyone have a grader blade under their tractor? in reply to don t. - 9n180179, 11-13-2001 08:20:52
Occasionally change the angle of your blade and play with the pitch. Don’t grade with a “dry” blade. Keep a healthy amount of dirt in it. To finish, reverse your blade and drag it backwards
ED-Illinois
11-13-2001 08:47:00
Have you tried grading backwards? That way the wheels roll over the freshly graded portion of the drive instead of on the un-graded portion. This helps me to avoid the washboarding effect.
don t. - 9n180179
11-13-2001 09:47:47
 Re: Re: Re: Re: Does anyone have a grader blade under their tractor? in reply to ED-Illinois, 11-13-2001 08:47:00
Yes i did but on my last pass, i went forward. I think this last pass was what caused it.
Thanks much for the tip. Can't wait to go home & try it. ....don t. .....
