3 or 4 rings on new rebuild??
8N-Dan
11-16-2001 19:23:41
Hi all.
I have just finished tearing down my 8N for a complete rebuild. It is my first N and I am not sure which pistons to order. 3 or 4 Rings. Which is better and why? I will be replacing all the sleeves and valves, oil pump etc.
Thanks in advance for your help, and I am sure I will have more questions before I am finished.
Wish me luck
Dan.
8N-Dan
11-17-2001 18:22:11
 Re: 3 or 4 rings on new rebuild?? in reply to 8N-Dan, 11-16-2001 19:23:41
Thank you all for the advice. It is unanimous, 3 rings are the way to go. So that's what I will do.
Thanks again
8N-Dan.
good luck on yer rebuild..............roperboy
11-17-2001 19:13:33
 Re: Re: 3 or 4 rings on new rebuild?? in reply to 8N-Dan, 11-17-2001 18:22:11
MikeC
11-17-2001 03:05:20
I went with the 3 ring pistons on mine also. Like roperboy, my FNH dealer recommended them to me and I trust what they tell me (they have been great so far).
Dell (WA)
11-16-2001 21:49:01
Dan..... ..go with the 3-rings. Modern 3-ring pistons are more efficent vs 4-ring. The modern oil control ring design is much more effective than the 2 oil rings of the 4-ring design. Modern ring metallurgy is also much better than the original rings too. Good luck on your rebuild..... ..Dell
the above message is from roperboy
11-16-2001 21:35:01
 Re: Re: 3 or 4 rings on new rebuild?? in reply to sojourn@iland.net, 11-16-2001 21:31:54
dont know how my e-mail showed up instead of name. i'm computer challenged
