Any Tricks? Splitting tractor for stuck clutch
Pokey
11-17-2001 16:16:01
I have had my clutch fastened down for three weeks with no release. Am going to split the 8N tomorrow to get it unfrozen. I would appreciate any tricks, shortcuts, or advice. Thanks, Pokey
Pokey
11-18-2001 14:26:43
 Re: Any Tricks? Splitting tractor for stuck clutch in reply to Pokey, 11-17-2001 16:16:01
Thanks for all the sugestions and tricks. A good friend came buy who used to sell Ns when they were knew and read all your replies. Said they all sounded good but You know you have a Sherman up and down in there i sure do not want to mess it up. How bout we try somthing NEW? He drilled a .578 or 37/64 hole just to the left of the inspection hole for the ring gear. Put in a srewdriver type tool and had the cluch free in no time. A little fiber optic light helped him see in the hole. Sealed the hole with a 3/8 pipe plug of brass. Works great.
John in Michigan
11-18-2001 05:08:26
Hi Pokey,
I did mine about 3 weeks ago. I used 2 floor jacks, one on each end of the tractor. Tips: (1)11/16 wrench takes off a lot of stuff,(2) you dont need to remove the starter unless you need to remove the flywheel after inspection (if you do remove starter put a nut on the starter bolt to hold it together while sitting out)(3) cut the heads off 2 bolts and use them to help realign the 2 halves of the tractor when putting it back together (4) you need a clutch alignment tool or a right sized shaft (5)Spin pto or fan belt to help align the splines when putting it back together (6) I would consider changing the throw out bearing while I was in there (7) inspect the flywheel and have it resurfaced and bearings changed if needed (7) don't rush and enjoy the work it's a fine machine to work on, even if it's a little greasy.
Richard(WY)
11-17-2001 21:27:30
take a trailer tongue jack with a wheel on it. Bolt it to the rear half where you split it and block up the engine/front half. take it apart and roll the rear half back carefully. really easy to do and no jacking with floor jacks or bottle jacks
9Njoe
11-17-2001 18:33:44
Use a cherry picker type engine hoist. Put slings under the crank case of the engine and take the weight off the front end.Separate the front end (axle/radiator)and swing it out of the way then block up under the tranny. Loosen the bolts between the tranny and engine and crack her apart.
Joe
Frank from Maine
11-17-2001 17:09:52
Hi Pokey...last spring my clutch stuck to the flywheel and wouldn't break free after tryin' this and that...:-) Here's what I did...removed starter...took a round quarter inch steel rod...flattened the end like a screw driver blade...bent it into a 45 degree angle in my vice...reached in and tapped the flattened end between the clutch and flywheel...viola they separated just fine...now i keep the clutch petal blocked with a scrap of two by four.
Paul haas - Pine island MN
11-17-2001 16:28:23
I have done it a grand total of once. I had an overhead hoist to support the steering, a mickey mouse floor jack, lotsa blocks, and a regular bottle jack. It took 3 hours start to finish because I read the I&T manual at least three times before I started, had everything I needed handy (except a good floor jack), there were no surprise leaks or bad bearings, and the transmission only
fell off the jack once. I will have a quality floor jack before I do it again, but I'm old and have experienced my full quota of terror.
If you're young and bold you can borrow my old one. The one tip I can give you is that you can turn the transmission input shaft
with the PTO to make the input shaft splines mate with the clutch. I struggled with getting them aligned so they would mate until that idea hit.
