Order Ford 8N Parts Online
2 belts on 8Ns?
Alan
11-17-2001 19:58:45
I just bought a 1950-1952 8N (still working on the serial number, but it is a late model). I used it for the first time and I heard a noise similar to a belt breaking. Turned it off and sure enough I found the remains of a belt. There is a brand new fan belt on it. So what (and where)is this 2nd belt for? It appeared to be in place between the actual fan belt and the fan itself. When I started it back up and parked it, it ran just fine. There is a loader on it (if that makes a difference). Any help would be greatly appreciated.
Alan
11-18-2001 08:45:20
 Re: 2 belts on 8Ns? in reply to Alan, 11-17-2001 19:58:45
Just got off the phone with the guy I bought it from. He said there was only one belt on it. He thought maybe it was an old one that was stuck in there some place.
steve19438
11-18-2001 05:18:54
i once saw a ferg. TO-20 with an aux. hyd. pump on the front driven by a sceond belt. it gave the tractor live hyd. for a front mounted snow blade.
1 belt is standard . . . Dell (WA)
11-17-2001 22:52:59
Alan..... .1 belt is standard for 8N's. Sometimes they can be a pain to replace if'n you have a frontend loader because you have to disconnect the hydraulic pump stinger from the crankshaft pulley to get the belt on. I always cut off the old belt..... .Dell
