Unusual noise in 20 hour old engine rebuild
Pokey
11-18-2001 17:16:09
Turning 50 two years ago was not so bad after finding out my wife and daughter had bougth me a restored 1939 9N. Engine had been redone and was only used for shows the past 10 years. I have put less then 4 hours on it since I have owned it. Today I heard a noise from the front of the engine that I thought was the water pump, but a very knowledge friend says it could be a rod bearing, wrist pin, or piston. The noise is not rythmatic and is louder as engine warms up. He advised me not to run the tractor. Can such a thing be repaired and what will it involve. Can it get worse? Thanks for any help. 52 now feels much older!!!! Pokey
VB
11-19-2001 19:51:59
 Re: Unusual noise in 20 hour old engine rebuild in reply to Pokey, 11-18-2001 17:16:09
Take your fan belt off and crank it up. If the noise is gone then you know it is the water pump. VB
Steve W
11-19-2001 07:10:18
Did you check for a pinhole exhaust leak? They sound like tapping sound, and would be consistant with a temperature change....start it up cold, and quickly use your hand to find the leaks...a stethascope works as well.
I hope that is what it is!
Take Care
Steve
matt452N
11-18-2001 18:41:40
Mine was making an unusual noise like that and turned out to be a loose sleeve.You might want to check that.
