Order Ford 9N Parts Online
9N Battery Box, what does it look like?
Paul Badowski
11-21-2001 16:26:17
I bought a battery box for my 9N from a tractor graveyard and was told the 8N and 9N battery box was the same. The 8N battery box is in the way of the starter button. How did the 9N battery box mount? Pictures would sure be great.
I posted a similar note a few hours ago. If it appears, sorry for the dup.
Is this what you are looking for?
11-23-2001 04:17:54
 Re: 9N Battery Box, what does it look like? in reply to Paul Badowski, 11-21-2001 16:26:17
third party image
This is a picture of my 2N battery tray before I fixed it. 9N similar I believe. Hope this helps.
Alan Esch
45 2N kit 183513
Paul - Where Does this mount
11-23-2001 08:39:47
 Re: Re: 9N Battery Box, what does it look like? in reply to Is this what you are looking for?, 11-23-2001 04:17:54
I have some rusty old pieces that may be the same as your photo.
Where does this mount?
Does the air cleaner bolt to it?
If not where does the air cleaner mount to?
Old George
11-23-2001 22:51:36
 Re: Re: Re: 9N Battery Box, what does it look like? in reply to Paul - Where Does this mount, 11-23-2001 08:39:47
Paul, it mounts on the upper steering housing with two bolts. Yes, the air cleaner does mount to this tray on the right side if you are sitting on the seat. Tool box mounts on the left side from seat. Hope this helps.
Alan
Correction/Addition
11-23-2001 23:07:05
 Re: Re: Re: Re: 9N Battery Box, what does it look like? in reply to Old George, 11-23-2001 22:51:36
Two to steering housing and two to the dash. Sorry about the initial ommision.
Alan
Tyler (MD)
11-21-2001 17:49:36
third party image
Those boxes are not the same. Each N-series box is made a little bit different from each other. The 9N/2N box mounts on the left hand side of the battery tray. The 8N box mounts near the back of the dash and is accessed through the fuel door.
third party image
Tyman
Paul
11-21-2001 19:12:00
 Re: Re: 9N Battery Box, what does it look like? in reply to Tyler (MD), 11-21-2001 17:49:36
The battery box I bought did not have a top and mounted flush on the top of the body using 2 bolts from the body. On my 9N the box would sit right on top of the starter button. It is 3 sided, one side free to slide in the battery.
It also has mounting locations for the air cleaner.
What is the battery tray?
