Brakes on 2n
Ron
11-25-2001 17:37:54
I just bought a great old 2n and am having trouble making the brakes work! when i take off the rear tire and adjust them ...they work fine...but when i put the wheel back on and try to stop...its like there is no brake at all...the pedal is tight but it takes a whole bunch of pressure to even slow it down...could the brakes be crystalized and if so how do i fix it????? ?
THANKS FOR ANY HELP OR Thoughts!!!
Old George
11-26-2001 05:14:26
 Re: brakes on 2n in reply to Ron, 11-25-2001 17:37:54
Ron, like Pete said, you probably are saturated with oil. you have a little grunt work ahead of you. My drums and everything inside were also saturated with oil. Cleaned up nicely though.third party image Might want to install neww pads at this time. Hope this helps. Alan Esch
45 2N kit 183513
Pete
11-25-2001 18:11:36
Ron, are the axle seals visibly leaking? With most tractors I would say that your pads are simply glazed and need to be roughed up, but with an N, they are probably saturated with oil. Pete
TimK
11-26-2001 07:46:13
 Re: Re: brakes on 2n in reply to Pete, 11-25-2001 18:11:36
While I agree that the pads are probably oiled up, unless you know that the pads are fairly new, like the last 10 years, don't fool with them, like sanding or burning off the oil. The older pads were made with asbestos. My $.02
